hi could someone help please i have googled from dusk till dawn and here is my problem every time i try to set my unit to home it goes the opposite way and will not stop that is on both x and y axis here is my console
Waiting for connection…
Port failed to open - already in use?
e[0;32mI (1331) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (1403) serial: Line state changed! dtr:0, rst:0e[0m
[VER:CV-30.V3.0.24.20221012]
e[0;32mI (2492) gpio: GPIO[13]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2515) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).e[0m
e[0;32mI (2516) gpio: GPIO[13]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0 e[0m
e[0;31mE (2518) sdmmcfs: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.e[0m
e[0;31mE (2519) sdmmcfs: TF mount failed
e[0m
e[0;32mI (2520) gpio: GPIO[15]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2522) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
e[0;32mI (2523) gpio: GPIO[14]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0 e[0m
[MSG:Axis count 2]
e[0;31mE (2634) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2635) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2636) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2638) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;32mI (2640) serial: Line state changed! dtr:0, rst:1e[0m
spindle_pwm_off_value:0.000000 spindle_pwm_min_value:0.000000 spindle_pwm_max_value:1023.000000
e[0;31mE (2644) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2646) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2647) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (2648) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
Grbl 1.3a [‘$’ for help]
ok
ok
ok
ok
ok
e[0;31mE (11077) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (11078) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
