I just got my Falcon 10 W and when I started it I tried to use auto search at lightburn but couldn’t find it so I added the file that came with my laser and it seems connected fine but it is firing all the time I upgraded the firmware as creality told me but still have the same problem it is fire all the time and I always have this message at the start (
Waiting for connection…
e[0;32mI (15220) serial: Line state changed! dtr:0, rst:1e[0m
e[0;32mI (18410) serial: Line state changed! dtr:0, rst:0e[0m
e[0;32mI (19445) serial: Line state changed! dtr:0, rst:1e[0m
ok
[VER:1.3a.20220818:]
[OPT:VH]
ok
Homing
e[0;31mE (19814) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (19815) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (20467) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (20469) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (20470) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
e[0;31mE (20471) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() firste[0m
ok
Starting stream
[MSG:Pgm End]
Stream completed in 0:00
I can’t do anything and searched everywhere but didn’t find any answer
anyone can help? thank you
