Hi,
The soft cover for my Creality Falcon 2 22W contains a fan. However, the fan
does not seem to work. I’ve had it (USB) plugged into the wall and the PC.
How can I get it to work or even test it? Your help is greatly appreciated.
-Kevin
Hi,
-Kevin
Hi Kevin
The Fan cable can easily come loose from the connector at the front.
Make sure the cable is fully pressed in, at the small white JST connector.
The screws holding the grate at the back of the fan were too tight. The grate was keeping the fan from turning. I loosened these screws and the fan works as expected now.
-Kevin
