Creality Falcon2 / GBRL / LB /WIN 10
Hello as a new user.
Creality Falcon2 / GBRL / LB / WIN 10
I have such a problem. After using the rotary engraving attachment, the machine does not read the working area correctly. The original scope was 400x400 mm. and now it is about 400x 270mm. It does not reach the limit switch and you can hear a grinding noise as if the belt were skipping over the gears. What could be the reason. Thank you in advance for your tips and help.
Is rotary mode still enabled in LightBurn?
Can you enter $$ in your console window and report back what it says?
Yes, I checked, it is turned off.
If you power the machine off and jog the axis by hand does it move freely?
So light and free.
