That’s not necessarily required. If you use the LB rotary wizard, you don’t need to change the steps. If you don’t use it, you have to.
The steps then depend on the mechanical setup and varies from vendor to vendor. At least for Sculpfun, I can tell that those values are mentioned in the user manual.
Here is some explanation on how to use the wizard:
