Creality Rotary Pro Issues
Hello all, I put this post up on redit but not getting any answers, as I’m sure I haven’t set up something correct in the Lightburn software. So here I go see if I can explain this correctly.
When I attempt to frame a object with the rotary pro all it does after it homes is run from one side to the other in the X axis and slam into the other side. What am I doing wrong I followed the instructions, but there isnt very much info or videos on YT to figure it out. PLease see link of my issue. And Thank y0u for any help in advance.
Rotary Pro issue video
If you use a rotary, you can’t use homing. Disable this. Then use current position as starting position.
Great Ill give it a try this weekend when I can get back in the garage. Thank you. I’ll let you know how it goes.
