Hello,
how can I construct a defined circular arc in Lightburn?
For example:
Height = 8cm
Length = 20cm
Thank you, greetings Jan
Hello,
For example:
Height = 8cm
Length = 20cm
Mathematically, for a circular arc, i’d need the radius of the circle to know how much curvature there is in the shape you’re describing.
The radius of the circle could be as small as 20cm, but the radius could be hundreds of meters if the intention was to have a very shallow circular arc.
We could define a quarter of an ellipse with the two numbers you’ve provided but that’s all I can gather.
I would draw the circle or ellipse with the ellipse tool then draw rectangles to provide guides for ‘Cut Shapes’.
I’d love to know more.
Knowing the chord length c and depth m, the circle radius is:
r = (m² + c²/4) / 2m
r = (64 + 400/4) / 16
r = 10.25
You could figure the angle, but I’d use a shortcut:
Numeric Edits toolbar)That will leave the segment (in red):
The blue lines show the circle and the offset square. Dimensions in millimeters, but that’s the general idea.
If you want just the arc, not the segment, delete the chord using the Node Editor tool.
I do this type of work in CAD software… LB is remarkably capable, but sometimes there ARE better alternatives.
Hi,
Thank You.
I don’t need exact circular arcs, they just have to be visually consistent from application to application.
Would it be possible to construct a normal semicircle and then edit its length and width?
So you could save yourself the complicated construction or am I making a mistake here?
Thanks & Greetings
Thanks. That should be enough ![]()
