Creatility CR falcon 10w wont outline the shape or laser engrave
hi I recently got myself a creatility CR Falcon 10w laser engraver and I set it up plugged it in uploaded a file onto the tf card pressed the button for it to outline the shape and it went to the corner, and then beeped 3 times so I pressed it again and the fans turned on and nothing happens please help if you know whats wrong
Did you put tf card in before powering up?
Sorry to ask questions that might seem dumb, but who know, sometime we miss some things.
What kind of file did you put in the TF card? Is it an Gcode file produced by LightBurn?
In LB, did you load the CR-Falcon settings shipped with the TF card, before producing the Gcode?
First time I test my CR-Falcon, it was with a file produced by LaserGRBL and it didn’t have the right settings, so I guess the XY axis was inverted or something like that, so it tried to go past the lower left corner… Even changing these settings didn’t produce good results, so I gave up and went for LB, which worked fine, of course. :slightly_smiling_face:
