Bottom Line Up Front: Looking for recommendations for alternative laser!
A 20w Diode should be sufficient for what want to do (mostly cut 1/8" plywood and basswood, plus smaller thickness cardboard/laserboard/taskboard sheets. And hopefully cut, or at least scribe styrene.)
Well, I got to the point where I was ready to connect using the Creality software to actually burn something. First I tried engraving, that worked OK, but for the test scrap cardboard I would need a lot more investigation to get expected results. So then I tried to cut out a rectangle from that cardboard. Again, Iâm sure I need to investigate settings to get the piece to cut properly. BUT the evacuation fan didnât work, so the box was full of smoke.
I probably could test the evacuation fan, but frankly thatâs a hassle, plus if itâs not the fan, then Iâm into bigger problems. And there are some other smaller issues with this, including a part that seems to stick out where it shouldnât.
Now âno fanâ strikes me as a safety hazard, on top of ânew product not working out of the boxâ. Iâm not impressed with Crealityâs tech support. A machine in this class should have a 2 digit LED for error code read-out, not âlisten for beeps and watch the blinky lights to guess which error code this isâŚâ And the AI ChatBot provided links to 2 videos on a server in China that wouldnât display (probably some browser security feature, but stillâŚ)
So, looking for advice from the collected wisdom here. Iâd probably get an XTool S1 if the 20w version was in stock I do like the idea of an enclosed unit, so I could run this (with an air filter) in the basement. Thanks in advance!
