I am watching a video tutorial and when he used the eclipse tool to draw a circle it draws a filled in circle. I draw a circle and it is just the outside line even after I set the layer to fill and not line. Anyone know why or how I change mine to show it filled in?
If you go to Window Menu> Filled Rendering you will see the fill in the work area. This is not recommended for most purposes as it makes selecting other items in the same area more difficult and it can hide things behind. You can quickly toggle the function with Alt-Shift-W keystroke.
The preview window always shows what will be filled and what will not.
