I am trying to create a pattern of 1 mm squares spaced approximately 1 mm apart in both the X and Y direction. The array will need to be about 25 mm by 70 mm in size.
I am modeling a building in wood and want to burn square windows on the side in a rectangular pattern. Fushion 360 allows me to create such a pattern but it would be easier to create the sides in Lightburn if I could also do the windows in a separate layer.
One practical consideration for this is that 1 mm squares separated 1 mm apart in a grid will be absolutely tiny, especially if you’re engraving on wood. You’re likely to lose much definition at that scale depending on equipment and specific material used.
Thanks. Will look at that process. I am not sure the dots will show up but I can adjust the scale slightly or add some lines to represent the building facade. Just didn’t want to put the feature together one square at a time.
