Creating and Editing Circular Text in LB
Hello to the LB community. I am a new user and have a question abpout LB’s ability to create and edit circular text in the LB editor.
We are currently using Corel Draw to create a circular text image, then exporting the *.ai file to the software interface, e.g. LB. This seems to work fine, but here is the caveat: Each burned image has a unique serial number. To increment or modify this circular serial number, we must go back into Corel Draw, modify the text, then re-export the *.ai file, then send it off to LB again and repeat this tedious and time-sinking process for each serial number in the series.
We were using RDWorks, which is a less-than desireable, zero editing interface and heard that with LB, one could toss both Corel Draw and its vector output files out. LB should be able to replace CD.
I have been able to accomplish this task in LB by replacing all the rotated text in the *.ai file with LB text and can modify the serial numbers in the LB editor, but again, I had to replace all the text in order to assure that there would be no problems with the appearance of the text; another serious time sink.
To sum this all up, is it possible to create and edit circular text in LB, and if so, how?
I am using a currently patched Win11 box with LB 2.0.04 and a Ruida 644 XS controller.
If you have read this far, I express my gratitude for any direction you may be able to provide, and the valuable time you have taken.
Hello again. I resolved the issue and found the editing icon to create and edit circular text.
