How do i create a horizontal or vertical lines or check that a line is horizontal or vertical in LB?
Thanks
Thanks
use the line tool… hold shift while drawing.
Hey Bob,
I hope you do make a lot of progress with your nice machine so far!
You can use “Draw Lines” to start anywhere you want and then hold the shift key to get lines in any 45° angle you would like. Try it out, it’s very handy.
Cheers,
Brian
Awesome!
Thank you Brian and Bjorn,
I am still playing around with LB, waiting on my daughter to create some items to create. Currently working on a monogram with my last name. Seemd like a fun project to create.
Will post when presentable.
Also you can draw a primitive shape (rectangle) and break it apart. You can also use these shapes as reference for alignment and two point pivots (ctrl+2 on windows) when you want to “level” objects on a common plane.
