How do you create designs that can be engraved on wood??Do i have to have a specific website or app??
I’d suggest going through the “Beginner Docs” section of the Documentation. This will help you get oriented and walk you through to a first project.
@berainlb is correct for starters…
You can google something like laser designs or svg designs laser that can be used on your laser…
I’m not an artist, so I’m lacking in those areas. I purchase commercial artwork as a general operation.
I do some of my own designs but they are generally for mounts or brackets…
The advantage of using prepared artwork is allows you start engraving with a know entity…
You can find many of these for free…
I should probably ask you why you purchase a laser… what ideas do you have to use it for…?
That should help us guide you to something more useful than google this or that…
Here’s a couple to play with…
Good luck
Thank you for the advice & designs!! i did figure out how to do it, i was mainly just trying to figure out a specific design but i found the free svg online.
