SayCheeze
(phillip)
September 19, 2023, 4:24pm
1
I’m a thinking of offering the service of creating name plates for plaques and such. I have a 50w CO2 and Fiber laser to use.
Can my CO2 cut this stuff?
Brass Sheets
Or maybe this stuff
Other Material
Maybe just buy it already cut?
Pre-Cut Stuff
What materials are you all using to do this type of work if you care to share?
jkwilborn
(Jack Wilborn)
September 19, 2023, 9:22pm
2
Co2 is not for direct metal use… if you wish to do that, you need something like LBT100 or Cermark … that you can lase onto the surface.
The acrylic, yes…
Brass plates, again, not with a co2 directly.
Both metals can be done with the fiber and it might to some extent work with acrylic, but fiber isn’t usually good with acrylic…
I made these from ACE hardware brass sheets and cut them with the fiber.
SayCheeze
(phillip)
September 19, 2023, 10:26pm
3
Thanks Mister J
I may just go the pre-cut stuff off of Amazon, and either mark it, or engrave it with the Fiber. I prefer to do work on my Fiber because I can see exactly where and what is going to be burned/engraved -vs- my CO2.
Or, do this method with plastic
Bearded Guy
jkwilborn
(Jack Wilborn)
September 19, 2023, 10:35pm
4
Pre-cut would be the most simple.
With the fiber you can bolt down a scrap piece of sheet metal and engrave a depression for part registration…
