Creating trinangles
I use Lightburn to create building for my model railroad. I want to know is there an easy way to create triangles
The way I do it:
Draw a square with the measurements of the 2 known sides, make it editable and delete the 4th node.
I just use the multi sided shape tool and select three sides.
Is the multi shape tool the same as the polygon tool
Yes, afterwards you must on the right side in properties for shape and determine the number of corners
Here is a visual I hope will assist. :slight_smile:
