Cropping PDF file
Wondering if you are able to crop a PDF that is imported to Lightburn
Once it’s imported, it’s not a pdf anymore, so it shouldn’t be a problem. (if I understood your question correctly)
I was wondering if I had 3 shapes in the file and only wanted cut one of them could I crop out the otjer 2
Thanks again
Do you have the option to send the file up here or as a pm to me?
Sorry it will not let me upload a PDF, if you have an actual email address I can email it to you
Thanks again for your help
I’m not entirely sure, but with some files you can just add “.txt” after the original ending and the system will accept it.
Sometimes I also get pdf files to work with and when they are read into LightBurn the shapes behave “normally” like the other formats like svg or dxf. It is no problem to process only individual shapes.
Thanks for the info, greatly appreciated
