Addd a crosshair to the module on Sculpfun AF-S9 but after measuring offsets and recording them and using current position the module wont move to required position of the image
The offset is applied when the job is output not when it is framing so the term '‘pointer offset’ can be confusing in that sense so think only about “Laser output offset”.
If you enable the ‘Laser Offset’, you should notice an immediate change in the position of the output. To test this, run a job like a plain square with this disabled, and then the same job again after enabling the setting.
Have you seen the documentation here?:
Laser Offset Setup - LightBurn Documentation
There is a method outlined to help you find the correct offset.
Thank you. OK now.
