sethripley
(Seth Ripley)
December 10, 2020, 8:56pm
1
So I’m fairly new to lasers, but am loving every minute of it! These forums have been a HUGE help, so thank you all for sharing tips and tricks.
I’ve recently run into an issue that I haven’t seen addressed on this forum, so please help!
I have a fairly weak laser with a GRBL controller, and no auto-focus.
I am attempting to fill a large section of a wood slice magnet, so I tried the crosshatch setting for the first time. What I found is that the first direction it burns (we’ll call it phase 1) does so at drastically reduced power. I have my fill set to 100% (albeit on a pretty weak 2.5w output laser). On the second pass (phase 2), it burns as normal. Yet try as I may every time I do the crosshatch it starts out with the weak power, and I cannot seem to find any setting to adjust this.
Is this a glitch in the software? Some focusing issue on my part? A setting that I’m somehow missing?
Thanks so much for your time, I hope I can find a solution to this!
What is the maximum speed of your laser in X & Y, and what speed have you chosen for the fill?
Also, diodes often focus to a line, not a point, and if that line is horizontal, that’s your optimum direction for power.
sethripley
(Seth Ripley)
December 10, 2020, 10:10pm
3
Thanks so much for your quick reply!
I attached an image with my speed settings. I used a speed of 450 for the crosshatch fill. I also experimented with 750 and 650 and the speed didn’t seem to change anything. I also have the line intervals pretty high (I believe .35) to have a distinct crosshatch pattern.
Thanks again for the quick response!!
sethripley
(Seth Ripley)
December 10, 2020, 10:12pm
4
Also, regarding the focus; in the same burn I’m also burning text with the laser going in all directions. There haven’t been any focus issues there, it started only with the criss hatch setting.
Thank you
Read the words on the screen shot you sent.
You said you used a speed of 450. 450 what? (mm/sec, mm/min, inches/decade, parsecs/fortnight?)
sethripley
(Seth Ripley)
December 11, 2020, 1:26pm
7
Lol sorry I’m fairly new to lasers and didn’t think to mention that; it was 450 mm/min
sethripley
(Seth Ripley)
December 11, 2020, 1:32pm
8
…sorry I’m not sure what you’re getting at? I try to decipher the settings but still feel like I’m learning a new language
Before you edited it, the screen shot was this one:
You have a diode laser - does it focus to a tiny dot, or a small line? If it’s a line, is the line horizontal? If so, that’s why when burning vertically you get less power.
sethripley
(Seth Ripley)
December 11, 2020, 5:45pm
10
Yes sorry I saw that because I wasn’t connected to the laser I had taken a screenshot of the wrong thing.
The laser focuses to a tiny dot, not a line. And I’m burning on a 45 degree angle for the crosshatch.
There’s only one power setting for crosshatch, so I still suspect a rectangular beam, or some other issue with the laser, wood grain, etc.
If you click “Save GCode” and post the output here I can verify that the power outputs are correct.
sethripley
(Seth Ripley)
December 12, 2020, 2:09am
12
; LightBurn 0.9.18
; GRBL-M3 (1.1e or earlier) device profile, current position
; Bounds: X-0.53 Y-0.53 to X39.4 Y22.34
G00 G17 G40 G21 G54
G91
; Scan+Cut @ 450 mm/min, 100% power
M8
M5
G0X38.23Y-0.53
; Layer C00
M3
G1X0.53Y0.53F450S0
G1X0.11Y0.11S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-0.75Y-0.75S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X1.39Y1.39S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-2.02Y-2.02S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X2.66Y2.66S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-3.3Y-3.29S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X3.93Y3.93S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-4.57Y-4.57S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X5.21Y5.2S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-5.84Y-5.84S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X6.48Y6.48S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-7.11Y-7.11S255
G1X-0.54Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X7.75Y7.75S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-8.39Y-8.39S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X9.02Y9.02S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-9.66Y-9.66S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X10.3Y10.29S255
G1X0.53Y0.54S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-10.93Y-10.93S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X11.57Y11.57S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-12.21Y-12.2S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X12.84Y12.84S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-13.48Y-13.48S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X14.12Y14.11S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-14.75Y-14.75S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X15.39Y15.39S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-16.02Y-16.02S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X16.66Y16.66S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-17.3Y-17.3S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X17.93Y17.93S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-18.57Y-18.57S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X19.21Y19.2S255
G1X0.53Y0.53S0
G1Y0.64S0
G1X-0.53Y-0.53S0
G1X-19.84Y-19.84S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X6.54Y6.54S255
G1X0.84Y0.83S0
G1X13.1Y13.11S255
G1X0.53Y0.53S0
G1Y0.63S0
G1X-0.53Y-0.53S0
G1X-11.29Y-11.28S255
G1X-2.86Y-2.86F4500S0
G1X-6.97Y-6.97F450S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X8.01Y8.01S255
G1X1.55Y1.55F4500S0
G1X12.19Y12.19F450S255
G1X0.53Y0.53S0
G1X-0.57Y0.06S0
G1X-0.53Y-0.53S0
G1X-10.79Y-10.79S255
G1X-2.34Y-2.34F4500S0
G1X-8.69Y-8.68F450S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.54Y0.53S0
G1X8.63Y8.63S255
G1X2.8Y2.81F4500S0
G1X10.38Y10.37F450S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-12.13Y-12.13S255
G1X-0.64Y-0.64S0
G1X-9.04Y-9.04S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X8.42Y8.42S255
G1X3.02Y3.02F4500S0
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-10.31Y-10.3S255
G1X-0.76Y-0.77S0
G1X-1.49Y-1.49S255
G1X-0.96Y-0.95S0
G1X-8.29Y-8.3S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X8.68Y8.68S255
G1X0.94Y0.94S0
G1X12.19Y12.19S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-9.82Y-9.82S255
G1X-1.04Y-1.04F4500S0
G1X-0.19Y-0.18F450S255
G1X-1.31Y-1.31F4500S0
G1X-9.46Y-9.46F450S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X8.43Y8.43S255
G1X1.39Y1.4F4500S0
G1X0.69Y0.69F450S255
G1X2.19Y2.19F4500S0
G1X9.11Y9.1F450S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.54Y-0.53S0
G1X-9.14Y-9.14S255
G1X-0.2Y-0.2S0
G1X-0.4Y-0.4S255
G1X-1.13Y-1.13F4500S0
G1X-1.48Y-1.48F450S255
G1X-0.73Y-0.73S0
G1X-8.73Y-8.73S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X9.32Y9.32S255
G1X1.62Y1.62F4500S0
G1X0.79Y0.78F450S255
G1X0.17Y0.18S0
G1X9.92Y9.91S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-10.4Y-10.4S255
G1X-0.98Y-0.98S0
G1X-10.43Y-10.43S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X8.37Y8.37S255
G1X3.07Y3.07F4500S0
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-10.21Y-10.2S255
G1X-1.12Y-1.13F4500S0
G1X-1.19Y-1.19F450S255
G1X-0.71Y-0.7S0
G1X-8.59Y-8.59S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X9.02Y9.02S255
G1X0.72Y0.72S0
G1X12.07Y12.07S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-10.49Y-10.48S255
G1X-1.76Y-1.76F4500S0
G1X-9.57Y-9.57F450S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X10.52Y10.53S255
G1X0.89Y0.88S0
G1X0.33Y0.34S255
G1X0.82Y0.82S0
G1X9.25Y9.24S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-21.81Y-21.81S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X8.79Y8.79S255
G1X2.32Y2.32F4500S0
G1X10.71Y10.7F450S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-9.91Y-9.91S255
G1X-0.75Y-0.74S0
G1X-1.32Y-1.32S255
G1X-1.42Y-1.42F4500S0
G1X-8.41Y-8.42F450S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X8.27Y8.27S255
G1X1.11Y1.11F4500S0
G1X2.52Y2.52F450S255
G1X0.59Y0.59S0
G1X9.32Y9.32S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-8.86Y-8.85S255
G1X-0.61Y-0.61S0
G1X-3.12Y-3.12S255
G1X-0.98Y-0.99S0
G1X-8.25Y-8.24S255
G1X-0.53Y-0.53S0
G1X-0.63S0
G1X0.53Y0.53S0
G1X8.54Y8.54S255
G1X0.75Y0.75S0
G1X3.34Y3.35S255
G1X0.72Y0.71S0
G1X8.46Y8.46S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-8.17Y-8.16S255
G1X-0.85Y-0.85S0
G1X-2.3Y-2.31S255
G1X-1.3Y-1.29F4500S0
G1X-9.2Y-9.2F450S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X10.41Y10.41S255
G1X1.75Y1.75F4500S0
G1X0.68Y0.68F450S255
G1X1.04Y1.04F4500S0
G1X7.94Y7.93F450S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-7.8Y-7.8S255
G1X-1.68Y-1.68F4500S0
G1X-12.33Y-12.33F450S255
G1X-0.53Y-0.53S0
G1X-0.64S0
G1X0.53Y0.53S0
G1X12.62Y12.62S255
G1X1.44Y1.44F4500S0
G1X7.76Y7.75F450S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-7.81Y-7.81S255
G1X-1.72Y-1.72F4500S0
G1X-0.02Y-0.01F450S255
G1X-0.54Y-0.55S0
G1X-11.66Y-11.66S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X11.19Y11.19S255
G1X1.91Y1.91F4500S0
G1X8.01Y8.01F450S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-8.42Y-8.41S255
G1X-0.83Y-0.84S0
G1X-11.23Y-11.22S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X19.84Y19.84S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-19.2Y-19.2S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X18.57Y18.56S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-17.93Y-17.93S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X17.3Y17.29S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-16.66Y-16.65S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X16.02Y16.02S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-15.39Y-15.38S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X14.75Y14.75S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-14.11Y-14.11S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X13.48Y13.47S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-12.84Y-12.84S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X12.2Y12.2S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-11.57Y-11.56S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X10.93Y10.93S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.54Y-0.53S0
G1X-10.29Y-10.29S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X9.66Y9.65S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-9.02Y-9.02S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X8.39Y8.38S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-7.75Y-7.74S255
G1X-0.53Y-0.54S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X7.11Y7.11S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-6.48Y-6.47S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X5.84Y5.84S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-5.2Y-5.2S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X4.57Y4.56S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-3.93Y-3.93S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X3.29Y3.29S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-2.66Y-2.65S255
G1X-0.53Y-0.53S0
G1Y0.63S0
G1X0.53Y0.53S0
G1X2.02Y2.02S255
G1X0.53Y0.53S0
G1X-0.63S0
G1X-0.53Y-0.53S0
G1X-1.39Y-1.38S255
G1X-0.53Y-0.53S0
G1Y0.64S0
G1X0.53Y0.53S0
G1X0.75Y0.74S255
G1X0.53Y0.53S0
G1X-0.64S0
G1X-0.53Y-0.53S0
G1X-0.11Y-0.11S255
G1X-0.53Y-0.53S0
M5
G0X39.93Y0
; Layer C00
M3
G1X-0.53Y0.53S0
G1X-0.11Y0.11S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X0.75Y-0.74S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-1.39Y1.38S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X2.02Y-2.02S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-2.66Y2.65S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X3.3Y-3.29S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-3.93Y3.93S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X4.57Y-4.56S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-5.21Y5.2S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X5.84Y-5.84S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-6.48Y6.47S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.54Y-0.53S0
G1X7.11Y-7.11S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.54S0
G1X-7.75Y7.74S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X8.39Y-8.38S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-9.02Y9.02S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X9.66Y-9.65S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-10.3Y10.29S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X10.93Y-10.93S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-11.57Y11.56S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X12.21Y-12.2S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-12.84Y12.84S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X13.48Y-13.47S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-14.12Y14.11S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X14.75Y-14.75S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-15.39Y15.38S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X16.02Y-16.02S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-16.66Y16.65S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X17.3Y-17.29S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-17.93Y17.93S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X18.57Y-18.56S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-19.21Y19.2S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X19.84Y-19.84S255
G1X0.53Y-0.53S0
G1Y-0.63S0
G1X-0.53Y0.53S0
G1X-20.48Y20.47S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X21.12Y-21.11S255
G1X0.53Y-0.53S0
G1Y-0.64S0
G1X-0.53Y0.53S0
G1X-21.75Y21.75S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X10.5Y-10.5S255
G1X0.5Y-0.49S0
G1X10.82Y-10.82S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-10.42Y10.42S255
G1X-0.55Y0.55S0
G1X-10.84Y10.84S255
G1X-0.54Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X9.05Y-9.04S255
G1X0.38Y-0.38S0
G1X0.85Y-0.85S255
G1X0.55Y-0.56S0
G1X0.35Y-0.34S255
G1X0.6Y-0.61S0
G1X0.3Y-0.3S255
G1X0.26Y-0.26S0
G1X9.47Y-9.47S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-9.14Y9.14S255
G1X-0.32Y0.32S0
G1X-0.19Y0.19S255
G1X-0.68Y0.67S0
G1X-0.29Y0.29S255
G1X-0.63Y0.64S0
G1X-0.51Y0.51S255
G1X-0.27Y0.27S0
G1X-0.03Y0.02S255
G1X-0.44Y0.45S0
G1X-9.32Y9.31S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X9.68Y-9.68S255
G1X0.78Y-0.78S0
G1X0.43Y-0.43S255
G1X0.64Y-0.64S0
G1X0.25Y-0.25S255
G1X0.77Y-0.77S0
G1X0.12Y-0.12S255
G1X0.33Y-0.33S0
G1X8.81Y-8.81S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-8.46Y8.46S255
G1X-0.36Y0.36S0
G1X-0.05Y0.05S255
G1X-0.35Y0.36S0
G1X-0.06Y0.06S255
G1X-0.47Y0.46S0
G1X-0.21Y0.22S255
G1X-0.6Y0.6S0
G1X-0.41Y0.41S255
G1X-1.07Y1.06F4500S0
G1X-9.77Y9.77F450S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X9.95Y-9.94S255
G1X0.92Y-0.93S0
G1X0.77Y-0.76S255
G1X0.56Y-0.57S0
G1X0.12Y-0.11S255
G1X0.53Y-0.53S0
G1X0.12Y-0.13S255
G1X0.73Y-0.72S0
G1X8.12Y-8.12S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-7.77Y7.77S255
G1X-0.68Y0.68S0
G1X-0.23Y0.23S255
G1X-1.11Y1.11F4500S0
G1X-0.75Y0.75F450S255
G1X-0.41Y0.41S0
G1X-0.04Y0.04S255
G1X-0.52Y0.52S0
G1X-10.3Y10.3S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X10.75Y-10.74S255
G1X0.14Y-0.15S0
G1X0.33Y-0.32S255
G1X0.47Y-0.48S0
G1X0.59Y-0.58S255
G1X0.3Y-0.3S0
G1X0.34Y-0.35S255
G1X0.43Y-0.42S0
G1X0.41Y-0.42S255
G1X0.64Y-0.64S0
G1X7.41Y-7.41S255
G1X0.54Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-7.05Y7.05S255
G1X-0.6Y0.6S0
G1X-1.27Y1.27S255
G1X-0.37Y0.37S0
G1X-0.35Y0.35S255
G1X-0.62Y0.62S0
G1X-0.62Y0.62S255
G1X-0.58Y0.58S0
G1X-10.36Y10.35S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X9.13Y-9.13S255
G1X0.35Y-0.35S0
G1X0.63Y-0.63S255
G1X0.21Y-0.21S0
G1X0.11Y-0.11S255
G1X0.89Y-0.89S0
G1X0.55Y-0.55S255
G1X1.31Y-1.31F4500S0
G1X1.42Y-1.42F450S255
G1X0.53Y-0.53S0
G1X6.68Y-6.68S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-8.38Y8.38S255
G1X-0.87Y0.87S0
G1X-0.16Y0.16S255
G1X-0.27Y0.26S0
G1X-0.47Y0.48S255
G1X-1.31Y1.31F4500S0
G1X-0.41Y0.41F450S255
G1X-0.6Y0.6S0
G1X-9.35Y9.34S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X9.77Y-9.76S255
G1X0.44Y-0.44S0
G1X0.5Y-0.5S255
G1X0.73Y-0.73S0
G1X0.21Y-0.21S255
G1X0.43Y-0.43S0
G1X0.29Y-0.29S255
G1X0.35Y-0.35S0
G1X0.43Y-0.43S255
G1X0.43Y-0.44S0
G1X8.24Y-8.23S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-8.79Y8.79S255
G1X-0.99Y0.99S0
G1X-0.29Y0.29S255
G1X-0.61Y0.61S0
G1X-0.41Y0.41S255
G1X-0.37Y0.38S0
G1X-10.35Y10.34S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X7.84Y-7.84S255
G1X1.47Y-1.46F4500S0
G1X1.23Y-1.24F450S255
G1X0.62Y-0.61S0
G1X0.67Y-0.67S255
G1X0.25Y-0.25S0
G1X0.42Y-0.42S255
G1X0.8Y-0.8S0
G1X8.52Y-8.52S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-9.43Y9.43S255
G1X-0.27Y0.27S0
G1X-0.6Y0.6S255
G1X-0.67Y0.67S0
G1X-0.86Y0.86S255
G1X-2.23Y2.23F4500S0
G1X-7.75Y7.75F450S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X7.79Y-7.79S255
G1X1.24Y-1.23F4500S0
G1X0.96Y-0.97F450S255
G1X0.54Y-0.54S0
G1X0.68Y-0.68S255
G1X0.63Y-0.62S0
G1X0.52Y-0.52S255
G1X0.37Y-0.38S0
G1X9.08Y-9.08S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-8.77Y8.77S255
G1X-0.52Y0.52S0
G1X-0.29Y0.29S255
G1X-0.63Y0.62S0
G1X-0.62Y0.62S255
G1X-0.43Y0.43S0
G1X-1.58Y1.59S255
G1X-1.08Y1.08F4500S0
G1X-7.9Y7.89F450S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X8.02Y-8.02S255
G1X1.16Y-1.16F4500S0
G1X1.79Y-1.79F450S255
G1X0.42Y-0.42S0
G1X0.73Y-0.73S255
G1X1.19Y-1.19F4500S0
G1X8.5Y-8.5F450S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-8.37Y8.37S255
G1X-0.59Y0.59S0
G1X-1.09Y1.1S255
G1X-0.43Y0.43S0
G1X-1.7Y1.69S255
G1X-0.34Y0.34S0
G1X-0.18Y0.18S255
G1X-0.92Y0.92S0
G1X-8.19Y8.19S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X8.39Y-8.38S255
G1X0.86Y-0.86S0
G1X0.41Y-0.41S255
G1X0.36Y-0.36S0
G1X1.61Y-1.61S255
G1X0.46Y-0.46S0
G1X9.73Y-9.73S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-9.43Y9.44S255
G1X-0.5Y0.49S0
G1X-1.48Y1.48S255
G1X-0.38Y0.38S0
G1X-0.42Y0.42S255
G1X-0.11Y0.11S0
G1X-0.09Y0.09S255
G1X-0.81Y0.81S0
G1X-8.59Y8.59S255
G1X-0.53Y0.53S0
G1X-0.64S0
G1X0.53Y-0.53S0
G1X8.9Y-8.89S255
G1X0.93Y-0.93S0
G1X0.57Y-0.58S255
G1X0.4Y-0.39S0
G1X1.31Y-1.32S255
G1X0.54Y-0.53S0
G1X9.17Y-9.17S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-8.93Y8.93S255
G1X-0.58Y0.58S0
G1X-1.11Y1.11S255
G1X-0.41Y0.41S0
G1X-0.77Y0.77S255
G1X-0.66Y0.66S0
G1X-9.36Y9.35S255
G1X-0.53Y0.53S0
G1X-0.63S0
G1X0.53Y-0.53S0
G1X10.02Y-10.02S255
G1X0.04Y-0.04S0
G1X1.11Y-1.11S255
G1X0.44Y-0.43S0
G1X0.85Y-0.86S255
G1X0.63Y-0.63S0
G1X8.72Y-8.72S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-8.54Y8.54S255
G1X-0.72Y0.71S0
G1X-0.54Y0.55S255
G1X-0.44Y0.43S0
G1X-11.58Y11.58S255
G1X-0.53Y0.53S0
G1X-0.57Y-0.06S0
G1X0.53Y-0.53S0
G1X11.94Y-11.94S255
G1X0.46Y-0.46S0
G1X0.1Y-0.1S255
G1X0.86Y-0.86S0
G1X8.39Y-8.39S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-8.29Y8.29S255
G1X-1.09Y1.09F4500S0
G1X-11.73Y11.73F450S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X11.63Y-11.64S255
G1X0.61Y-0.6S0
G1X8.24Y-8.24S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-19.84Y19.84S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X19.2Y-19.2S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-18.57Y18.57S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X17.93Y-17.93S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-17.3Y17.3S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X16.66Y-16.66S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-16.02Y16.02S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X15.39Y-15.39S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-14.75Y14.75S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X14.11Y-14.11S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-13.48Y13.48S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X12.84Y-12.84S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-12.2Y12.2S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X11.57Y-11.57S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-10.93Y10.93S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.54S0
G1X10.29Y-10.29S255
G1X0.54Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-9.66Y9.66S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X9.02Y-9.02S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-8.39Y8.39S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X7.75Y-7.75S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-7.11Y7.11S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X6.48Y-6.48S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-5.84Y5.84S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X5.2Y-5.2S255
G1X0.53Y-0.53S0
G1X-0.63S0
G1X-0.53Y0.53S0
G1X-4.57Y4.57S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X3.93Y-3.93S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-3.29Y3.29S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X2.66Y-2.66S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-2.02Y2.02S255
G1X-0.53Y0.53S0
G1Y-0.63S0
G1X0.53Y-0.53S0
G1X1.39Y-1.39S255
G1X0.53Y-0.53S0
G1X-0.64S0
G1X-0.53Y0.53S0
G1X-0.75Y0.75S255
G1X-0.53Y0.53S0
G1Y-0.64S0
G1X0.53Y-0.53S0
G1X0.11Y-0.11S255
G1X0.53Y-0.53S0
M5
G0X11.77Y9.82
; Layer C00
M3
G1X-0.02Y0.04S255F300
G1X0.09Y0.28
G1X0.15Y0.26
G1X0.58Y1.05
G1X0.65Y1.01
G1X0.18Y0.29
G1X0.16Y0.3
G1X0.02Y0.15
G1X-0.02Y0.15
G1X0.45Y0.02
G1X0.45Y-0.02
G1X0.18Y-0.02
G1X0.18Y-0.05
G1X0.18Y-0.06
G1X0.16Y-0.08
G1X0.11Y-0.06
G1X0.17Y-0.16
G1X0.12Y-0.2
G1X0.08Y-0.21
G1X0.02Y-0.25
G1X-0.02Y-0.25
G1X-0.06Y-0.23
G1X-0.1Y-0.23
G1X-0.15Y-0.24
G1X-0.18Y-0.22
G1X-0.2Y-0.2
G1X-0.22Y-0.19
G1X-0.53Y-0.35
G1X-0.57Y-0.28
G1X-0.6Y-0.19
G1X-0.63Y-0.12
G1X-0.19Y-0.01
G1X-0.19
G1X-0.13Y0.02
G1X-0.12Y0.05
M5
G0X-0.69Y0.07
; Layer C00
M3
G1X-0.06Y-0.23
G1X-0.03Y-0.23
G1X0.01Y-0.23
G1X0.04Y-0.23
G1X0.06Y-0.1
G1X0.1Y-0.06
G1X0.14Y-0.04
G1X0.15Y-0.01
G1X0.42Y0.02
G1X0.44Y0.06
G1X0.43Y0.1
G1X0.42Y0.12
G1X0.41Y0.16
G1X0.39Y0.19
G1X0.38Y0.22
G1X0.37Y0.25
G1X0.34Y0.28
G1X0.22Y0.21
G1X0.2Y0.22
G1X0.19Y0.24
G1X0.17Y0.25
G1X0.18Y0.35
G1X0.14Y0.35
G1X0.07Y0.36
G1X0.03Y0.29
G1X-0.01Y0.3
G1X-0.04Y0.31
G1X-0.09Y0.3
G1X-0.14Y0.28
G1X-0.18Y0.26
G1X-0.23Y0.22
G1X-0.26Y0.18
G1X-0.28Y0.14
G1X-0.31Y0.09
G1X-0.36Y0.06
G1X-0.36Y0.02
G1X-0.36Y-0.01
G1X-0.36Y-0.05
G1X-0.54Y-0.11
G1X-0.52Y-0.15
G1X-0.51Y-0.19
G1X-0.49Y-0.23
G1X-0.14Y-0.08
G1X-0.14Y-0.09
G1X-0.12Y-0.11
G1X-0.11Y-0.12
G1X-0.08Y-0.16
G1X-0.07Y-0.17
G1X-0.04Y-0.18
G1X-0.02Y-0.19
G1Y-0.17
G1X0.02Y-0.16
G1X0.05Y-0.12
G1X0.1Y-0.06
G1X0.18Y-0.02
G1X0.18Y0.05
G1X0.39Y0.16
G1X0.39Y0.16
G1X0.22Y0.13
G1X0.2Y0.14
G1X-0.37Y-0.02
G1X-0.36Y-0.05
G1X0.41Y0.17
G1X0.42Y0.14
G1X0.44Y0.12
G1X0.45Y0.1
G1X-0.4Y-0.52
G1X-0.39Y-0.54
G1X-0.37Y-0.54
G1X-0.35Y-0.56
G1X-0.36Y-0.62
G1X-0.3Y-0.65
M5
G0X5.42Y0.22
; Layer C00
M3
G1X0.02Y-0.21
G1X0.03Y-0.21
G1X0.05Y-0.2
G1X0.08Y-0.19
G1X0.11Y-0.19
G1X0.13Y-0.12
G1X0.16Y-0.07
G1X0.19Y-0.03
G1X0.24Y0.05
G1X0.22Y0.11
G1X0.22Y0.15
G1X0.2Y0.16
G1X0.18Y0.19
G1X0.17Y0.19
G1X0.21Y0.26
G1Y0.02
G1X0.23Y0.18
G1X0.2Y0.2
G1X0.2Y0.23
G1X0.15Y0.26
G1X0.33Y0.05
G1X0.33Y0.07
G1X-0.21Y-0.17
G1X-0.16Y-0.22
G1X-0.15Y-0.25
G1X-0.12Y-0.27
G1X-0.08Y-0.23
G1X-0.02Y-0.15
G1Y-0.16
G1X0.03Y-0.16
G1X0.05Y-0.15
G1X0.08Y-0.14
G1X0.12Y-0.1
G1X0.15Y-0.05
G1X0.16
G1X0.15Y0.05
G1X0.14Y0.07
G1X0.45Y0.37
G1X0.42Y0.41
G1X0.07Y0.07
G1X0.11Y0.05
G1X0.1Y0.05
G1X0.06Y0.07
G1X0.06Y0.06
G1X-0.13Y-0.3
G1X-0.09Y-0.31
G1X-0.02Y-0.21
G1X0.04Y-0.21
G1X0.06Y-0.15
G1X0.11Y-0.12
G1X0.14Y-0.08
G1X0.16Y-0.02
G1X0.17Y0.02
G1X0.16Y0.06
G1X0.32Y0.19
G1X0.31Y0.22
G1X0.36Y0.34
G1X0.35Y0.35
G1X0.05Y-0.23
G1X0.08Y-0.22
G1X0.11Y-0.2
G1X0.14Y-0.19
G1X0.11Y-0.08
G1X0.11Y-0.03
G1X0.22Y0.08
G1X0.19Y0.13
G1X0.2Y0.16
G1X0.19Y0.16
G1X0.56Y0.57
G1X-0.59Y-0.9
G1X-0.55Y-0.93
G1X-0.13Y-0.25
G1X-0.11Y-0.27
G1X-0.01Y-0.15
G1X0.02Y-0.15
G1X0.04Y-0.15
G1X0.06Y-0.13
G1X0.08Y-0.09
G1X0.11Y-0.03
G1X0.08Y0.02
G1X0.13Y0.13
G1X0.11Y0.15
G1X0.53Y0.7
G1X0.55Y0.68
G1X0.57Y0.67
G1X0.59Y0.65
G1Y0.39
G1X-0.21Y-0.12
G1X-0.21Y-0.13
G1X-0.19Y-0.16
G1X-0.18Y-0.17
G1X-0.36Y-0.36
G1X-0.37Y-0.36
G1X0.63Y0.98
G1X0.65Y0.98
G1X0.08Y0.13
G1X0.06Y0.14
G1X0.03Y0.15
G1X-0.01Y0.14
G1X-0.04Y0.14
G1X-0.08Y0.13
G1X-0.06Y0.04
G1X-0.07Y0.02
G1X-0.08
G1X-0.07Y-0.03
G1X-0.2Y-0.19
G1X-0.18Y-0.22
G1X-0.35Y-0.39
G1X-0.38Y-0.37
G1X-0.4Y-0.33
G1X-0.42Y-0.31
G1X-0.13Y-0.07
G1X-0.13Y-0.07
G1X-0.04Y-0.02
G1X-0.04Y0.01
G1X-0.01Y0.02
G1X0.05Y0.15
G1X0.05Y0.15
G1X0.27Y0.23
G1X0.26Y0.24
G1X0.24Y0.26
G1X0.22Y0.27
G1X0.11Y0.16
G1X0.08Y0.18
G1Y0.1
G1X-0.02Y0.09
G1X-0.04Y0.09
G1X-0.06Y0.08
G1X-0.13Y0.1
G1X-0.16Y0.04
G1X-0.15Y-0.05
G1X-0.14Y-0.09
G1X-0.36Y-0.32
G1X-0.32Y-0.35
G1X-0.28Y-0.39
G1X-0.24Y-0.41
G1X-0.03Y-0.07
G1X-0.02Y-0.08
G1X-0.43Y-0.28
G1X-0.42Y-0.28
G1X-0.13Y-0.06
G1X-0.14Y-0.03
G1X-0.08Y0.03
G1X-0.05Y0.09
G1X-0.01Y0.09
G1X0.05Y0.34
G1X0.13Y0.32
G1X0.22Y0.45
G1X0.25Y0.43
G1X0.28Y-0.03
G1X0.28Y-0.01
G1X0.35Y0.51
G1X0.29Y0.55
G1X-0.21Y0.03
G1X-0.22Y0.02
G1X0.25Y0.24
G1X0.19Y0.29
G1X0.02Y0.05
G1X-0.02Y0.08
G1X-0.06Y0.06
G1X-0.19Y0.05
G1X-0.18Y-0.01
G1X-0.18Y-0.06
G1X-0.15Y-0.11
G1X-0.22Y-0.26
G1X-0.18Y-0.29
G1X-0.38Y-0.01
G1X-0.37Y-0.06
G1X-0.11Y-0.05
G1X-0.11Y-0.07
G1X-0.09Y-0.09
G1X-0.07Y-0.09
G1X-0.19Y-0.28
G1X-0.12Y-0.31
G1X-0.02Y-0.08
G1X0.02Y-0.08
G1X0.03Y-0.03
G1X0.11
G1X0.1Y0.04
G1X0.27Y0.03
G1X0.26Y0.01
G1X-0.23Y-0.31
G1X-0.24Y-0.29
G1X-0.27Y-0.28
G1X-0.27Y-0.26
G1X-0.37Y-0.24
G1X-0.4Y-0.2
G1X-0.13Y-0.04
G1X-0.13Y0.03
G1X-0.03Y0.04
G1Y0.1
G1X0.02Y0.1
G1X0.12Y0.25
G1X0.14Y0.24
G1X0.17Y0.21
G1X0.19Y0.2
G1X0.11Y0.12
G1X0.08Y0.14
G1X0.02Y0.21
G1X-0.05Y0.22
G1X-0.06Y0.13
G1X-0.12Y0.09
G1X-0.25Y0.02
G1X-0.25Y-0.03
G1X-0.32Y-0.05
G1X-0.32Y-0.05
G1X0.09Y0.09
G1X0.04Y0.11
G1X-0.02Y0.1
G1X-0.07Y0.06
G1X-0.17Y-0.01
G1X-0.15Y-0.07
G1X-0.14Y-0.1
G1X-0.13Y-0.13
G1X-0.22Y-0.27
G1X-0.16Y-0.3
G1X-0.05Y-0.11
G1X-0.02Y-0.11
G1X-0.01Y-0.11
G1X0.02Y-0.12
G1X0.04Y-0.07
G1X0.05Y-0.07
G1X0.07Y-0.04
G1X0.08Y-0.03
G1X-0.16Y-0.16
G1X-0.14Y-0.17
G1X-0.39Y-0.24
G1X-0.39Y-0.24
G1X-0.1Y-0.04
G1X-0.1Y-0.03
G1X-0.11
G1X-0.11Y0.01
G1X-0.09Y0.05
G1X-0.06Y0.08
G1X-0.03Y0.09
G1Y0.1
G1X0.06Y0.15
G1X0.11Y0.13
G1X0.23Y0.25
G1X0.25Y0.25
G1X0.2Y0.28
G1X0.15Y0.31
G1X0.04Y0.16
G1X-0.02Y0.16
G1X-0.06Y0.09
G1X-0.11Y0.05
G1X-0.11Y0.02
G1X-0.1Y-0.01
G1X-0.11Y-0.02
G1X-0.1Y-0.04
G1X-0.17Y-0.09
G1X-0.16Y-0.12
G1X-0.14Y-0.13
G1X-0.12Y-0.15
G1X-0.26Y-0.35
G1X-0.22Y-0.37
G1X-0.07Y-0.2
G1X-0.04Y-0.2
G1X-0.01Y-0.21
M5
G0X1.7Y2.04
; Layer C00
M3
G1X0.13Y-0.02
G1X0.13Y0.01
G1X0.17Y0.09
G1X0.14Y0.14
G1X0.08Y0.1
G1X0.06Y0.11
G1X0.04Y0.12
G1X0.02Y0.13
G1X-0.02Y0.13
G1X-0.06Y0.11
G1X-0.1Y0.09
G1X-0.13Y0.05
G1X-0.11
G1X-0.11Y-0.02
G1X-0.1Y-0.05
G1X-0.08Y-0.07
G1X-0.1Y-0.1
G1X-0.08Y-0.11
G1X-0.06Y-0.13
G1X-0.05Y-0.13
G1X-0.01Y-0.14
G1X0.04Y-0.13
G1X0.08Y-0.11
G1X0.12Y-0.07
M5
G0X-18.84Y10.19
; Layer C00
M3
G1X38.87
G1Y-21.81
G1X-38.87
G1Y21.81
M5
M9
G1S0
; return to starting pos
G0 X-0Y-21.81
M2
sethripley
(Seth Ripley)
December 12, 2020, 2:10am
13
This isn’t my whole burn, but the forum wouldn’t let me post the whole thing so I removed other components and made the size of what I’m trying to crosshatch smaller to fit the gcode in the reply. Let me know if you need anything else or have any other suggestions.
I meant attach the text file , not copy the text into a message. Regardless, every line of that file is showing F4500 and S255 (75mm/sec) and 100% power during the cross-hatch, and 300mm/min (5mm/sec) for the final cut. The issue is the diode.
sethripley
(Seth Ripley)
December 14, 2020, 7:38pm
15
My apologies, I misunderstood.
Thank you very much for taking a look at it! Could it be a focus issue, or with it burning correctly in the second direction do you think it’s not the focus but that the diode itself is going bad?
Thank you again for taking the time to consider the issue, I really appreciate it!
If the diode were going bad, it wouldn’t work in either direction. High power diodes are usually rectangular arrays of emitters, not just a single emitter, so they work best if you move with the long side.
system
(system)
Closed
January 13, 2021, 8:26pm
17
