Hola, tengo un problema, cada ves que quiero hacer un grabado con rotación en algo cilíndrico en la segunda pasada se empieza a desfasar y no se que hacer.
Hello, I have a problem, every time I want to make an engraving with rotation in something cylindrical in the second pass it starts to go out of phase and I don’t know what to do.
You should avoid using multiple passes on round objects. They tend to slip a lot. Adjust the settings to do just one pass.
You can reduce the acceleration for the axis you are using (y usually) to for example 50mm/sec², which helps a bit. And only use slow movements. Adding weight into the opbject also helps.
Hello David,
I see that you rolled back a translation provided by our staff.
The forum is primarily an English language service. The translations allow people who don’t speak your language to offer technical support, ideas and information. Curating information in one language helps us index, search and link resources to help users sooner by offering previously documented solutions. We also translate Posts originally in German, Italian, French, Portuguese, and Mandarin as they appear. They are imperfect because we use a translation service online.
The answers provided are for all users, even for future users who do not yet own a laser. It is important for us to find and reduce the obstacles that our community members encounter on their journey.
