Hi,
I am a new user of the Cubiio2 and really like lightburn (even though I cannot connect directly to the Cubiio2 - it has a wifi connection only, not via usb). The created Gcode for the Marlin profile is almost 100% directly usable there is only one thing that would need to be changed and it would be great if the Lightburn team could provide a cubiio2 profile.
Below is an example of a Marlin created gcode of a square:
;USER START SCRIPT
G21
G90
; Cut @ 300 mm/min, 100% power
M107
M05
G0X10 Y7.5 F0
; Layer C01
M03 P100 S255
G1 Y23.5 F300
G1X26
G1 Y7.5
G1X10
M107
M05
G90
This code works fine, there is only a very minor tweak to be made;
Remove the F0 from the first command where the laser moves to the starting position so
instead of
G0X10 Y7.5 F0
change to
G0X10 Y7.5
The second bit (which is not really important) is the
M107
command (Fan off for Marlin).
It is ignored by Cubiio2 as its Fan is controlled by software.
So this simply change of removing F0 from the Gcode is enough (Cubiio2 actually works also with this command, it just pauses about 5 seconds before it starts here.
As the cubiio is a autofocus machine currenlty it would be great if the depth could be controlled if there are multiple passes, but here I am not sure if this is controlled by a gcode (I try to find out from the cubiio2 team).
Thanks and cheers
