Current List of UDP Commands
Is there a current list of UDP commands available? In particular I was curious if there was an Import command available… something that could add the contents of one file to an already open session. I have read the other related threads, but those are closed, so I wasn’t able to reply to one of those.
The use case is that I want to open a template file and then I want to load an art file.
UDP is Ethernet between Lightburn and the Ruida or dsp.
Do you want to load a file in the Ruida or Lightburn work area?
There are lists of the knows Ruida opcodes.
There is very limited api to Lightburn from my understanding.
Good luck
I haven’t heard of the SendUDP command set being expanded any time recently.
Perhaps combine the template file and art file prior to sending to LightBurn. Inkscape is scriptable and I believe could handle this.
