Custom Build 80W CO2 Laser Cutter
So I present you my custom build. 80W CO2 Cutter, using a Cohesion3D Laserboard for the controller, a Windows Surface Pro 2 tablet as the computer, Lightburn as the software, GRBL. I posted about this on the Cohesion forum and Openbuilds as well, in case you have seen it already.
My initial inspiration came from the Layzor K40 upgrade build by Frederico from man made mayhem. https://www.manmademayhem.com/?p=3440
After a few weeks of finding that build and drooling all over it, I decided to take the plunge and design my own from the ground up. Here she is.
So near the end of 2018, I got the idea to build my own custom laser and this is the result. Overall I probably spent between $5,000 and $6,000 to build it for those of you that will be curious. There’s about $1,000 in extruded aluminum alone. A lot of money went into the looks of it, I could have cut a lot of costs if I hadn’t decided to make it see-through and RGB. The lights might be useless, but they sure look pretty.
I took a bunch of pictures during the build, here are a few showing the progress.
I’ll add more tomorrow.
Very nice! That is a great frame system. Where did you source your aluminum parts?
What is the source for your honeycomb?
Wow great Job!! it looks Awesome!!!
Holy heck! That thing is crazy. Great work.
LightBurn Master Race! :rofl:
That’s beyond awesome. Now if only LightBurn could handle LED contro… BRB, gotta post something to lightburn.fider.io…
Awesome build. Thanks for sharing.
@Chico - I always wonder when I see builds like this… how did you go about actually designing it? Did you CAD model it first or just dive in and start cutting aluminum extrusion? :stuck_out_tongue:
I did a little bit of this and a little bit of that. I first designed a frame on SketchUp and color-coded the model to help me get started. I cut the pieces, assembled the frame, and figured everything else out as I went which made it fun. I ended up adding a lot more pieces to the frame but I cut those as I went along.
I honestly hadn’t even thought about how to attach the tube. When it came down to figuring that out I just held the tube in place with zip ties and figured everything else around that. Eventually, I came up with these. They grip around the tube, get bolted together, and then gets bolted to the frame.
I have a few other projects in mind and they will happen similarly. I’ll design the frame and figure everything else hands-on.
This was me trying to figure out how I was going to be running some of the cables and the air line. Now that it is all done I miss tinkering with it.
I hear ya, i’m closing in on finishing my custom build. It is like nearing the end of a really great book :slight_smile:
Don’t worry Gordon, these projects never end:-) I am actually using my 50W home build to make money now, but still seem to find ways of improving it!
Cheers
David
I just joined this forum, and the first post I see is this… Wow man really cool!
I’m happy the LAYZOR inspires people but this is more than inspiration, that is taking it to the next level!
Really stunning machine, and don’t worry, you’ll be tinkering with it for a long time to come. :wink:
Greetings,
Fred
Thanks. So near the end of last year I was in need of another laser and I had a k40 that was in pieces so I got curious and googled to see what my upgrade options were when I ran across your build. After drooling over the Layzor build for a few weeks, I decided to just do it and started buying the extruded aluminum. After a few revisions I realized that instead of upgrading the K40 I should probably just make something beefier and thus she was born.
This was my first build ever. Before I built this machine I wasn’t even sure where I could source replacement parts for my red black Chinese clone. If I hadn’t found your build online I would have never even thought about making something like this, it honestly would have never crossed my mind.
I have more pictures and videos on the Openbuilds website https://openbuilds.com/builds/custom-build-80w-co2-laser-cutter.8012/
nice!
This may sound very random, but I’m impressed by the way you did the angled frame. My very first design iteration also featured this, but it turned out that the 135° corner brackets were relatively expensive and would needlessly drive up the conversion cost for me. You figured out an alternative cheap way I would never have come up with. Very clever :wink:
I’ll be sure to read through the build log.
@xfedericox You inspired me too, Fred!
Walter
My 50 Watt machine …
Sint-Katelijne-Waver… bijna buren dus vanuit het forum gezien :wink:
Heck yeah, looks awesome man. Makes me want to build again.
Really impressed, not a rgb fan but this was awsome!
Would you kindly tell me what kind of protection glass you have been using? I’m rebuilding from 6040 to 70130 myself and need some 10600nm protection glass :slight_smile: or is it just shaded plexi?
Thanks :slight_smile:
Standard plexiglass is opaque to the 10600nm wavelength. You do not need tinted, clear will do. (The tint WILL help with the bright visible light that is emmited as part of the vaporization process.)
What @Grumpy_Old_Man said. I just tinted mine for the brightness.
