Where can I find information to customize LightBurn’s Home Page? I want to add the Art Library plus other tabs on the lower right corner next to the Laser and Library icon. If I go to Windows and click on Art Library it opens the library window but the icon does not load next to the Laser and Library icons.
You can dock the Art Library window into the pane shared by Laser and Material Library.
Click on the titlebar of the Art Library window and drag the window onto the pane where you want it docked. The pane will highlight in blue when it is prepared to dock the window. You may need to experiment with precise location and it can be a little finnicky. Just experiment with moving the pointer around different spots. Move slowly or else the blue highlight may not show up.
Worked perfect, thank you!!
