Here’s a little trick i use to cut a job into 2 parts
I use this when i have a job that has a long run time and i dont want to cut the whole job at once
This only works if the whole job will fit in the work area
Here is the document that explains. This is a word document so download then remove the .txt from the end of the file name
Quick Trick to Break up a Job into Smaller Parts.txt (332.1 KB)
