AtomStack A40 has started doing a strange thing. When I press the framing button, the laser head moves in the expected area, but when I start the cut, the laser head rapidly goes up to the upper right side of the bed and starts cutting up there. It is not even in the box defined by the framing. I restarted the laser. I restarted LightBurn, I restarted the computer and nothing seems to help. I tried using a different file, I tried a very small simple file with no results.The odd thing is it was working perfectly fine before this started about halfway through the day. I have not changed any settings, and just to be sure some gremlin did not tweak the settings for me, I looked in the machine and device settings and everything looks normal.
That you know about. but check them anyway. Could be coordinate mode selection, rotary mode enabled, or something else.
