I noticed that after update “Cut inner shape first” doesn’t works even it is selected. Any idea why ?
I am not seeing the same issue as you describe when using the most public release. You have not said what version you are using. Saying “after update” does not confirm the version number including the date/time of the release. This information can be found when clicking ‘Help’→’Quick Help and Notes’, then click on the ‘About’ tab to expose.
The only time I’ve ever seen this fail was when shapes were not connected - four lines the touch each other are not the same as a single continuous square - shapes have to be joined into continuous paths for the software to know what’s “inside” and “outside”.
Everything is fine now, thanks for reply.
