My frame is perfect with the laser dot. When I start the job from home, it goes to the corner of the object (square), then the laser head moves upwards a few inches and starts firing. It continues firing until it reaches the corner of the square and then it finally moves in the correct path.
I’m in absolute coordinates and have tried restarting the device, using a new lightburn file, and this still happens.
Okay. I can see that your Pointer offset is disabled but I wonder if it’s still somehow related to that.
What happens if you try enabling that and trying different offset values? Does this affect the behavior you were describing? If so, does going to 0,0 eliminate it entirely?
