Having a problem with just my cut layer shifting a couple mm to the right. I’ve ran 1000’s of small projects similar to this, just started out of the blue. I did the layout of this custom ornament, grouped it, rotated it about 45 degrees, then arrayed to get 16 on a sheet. Preview shows everything just fine, but when the actual cutting takes place, it’s out of alignment. Anybody else ever have this happen? I even deleted it all, opened a fresh file and did it all over again…
Hi Thomas,
I have the same problem. Could you fix it?
Greetings
