Is there any way to rename the layers for a project,without having to change it back for every other file. I renamed them for one file but now that is the default for every file
If you enable “Settings->File Settings->Load default layer settings on new or restart” it will take the default settings defined for every new file. So basically starting from a clean slate.
Some people rely on layer settings not changing across restarts/new files so that’s why those settings are sticky by default.
