Hi there,
I would like to make one of my projects but I am not sure how to proceed
I am runner and I am tracking my runs with Garmin watch so I have .gpx file of my running route.
What I want to achieve is to engrave map of area where I ran and cut the running route. I can imagine this as 2 layers where one (map) will be engraved and second (my running route) will be cut.
But I really have no idea how to achieve this.
I am usually using LightBurn and Inkscape SW
There’s also an inkscape extension using that tool if you want to bring into Inkscape directly. This seems unnecessary as you could go from gpx → svg → LightBurn but could be useful if you do this a lot and want to edit in Inkscape. Inkgpx2svg - Inkspace the Inkscape Gallery | Inkscape
You can likely download map data from openstreetmaps or other sources of GIS data
The usual meaning of Cut would result in your route falling out of the map, which is probably not what you expect.
Most likely, you want to engrave the map, then highlight your route using darker / bolder / wider engraving based on the GPX data. In that case, you’ll have the map on one layer with appropriate engraving settings and the route on another layer with different engraving settings. Those layers will have Fill settings.
In any event, you’ll definitely want a rectangle around the map perimeter, which goes on another layer with Line settings to cut it out of the stock material.
@ednisley - falling out is exactly what I am lookiing for, because that empty space I would like to fill with colored epoxy
this is what I found to get SVN from GPX GPX to SVG online Converter - so that could be layer for cut. Just not sure how to place this layer into another layer with map (and fit) which will be engraved
@berainlb thank you also for your suggestion
“You can likely download map data from openstreetmaps or other sources of GIS data” - you mean to download the map and then as upper layer place the SVN from GPX on it?
When I will laser this it will be single line, so the cut into wood will be as thick as laser beam (so very narrow). So I would need Lightburn thinks about the route not as line, but “rectangle”
So when laser finishes the cut the route is not e.g 0,2mm narrow, but let say 1mm
Assuming you started with an SVG you can use Offset Shapes tool to create a wider closed shape around the existing line. This will give the appearance of a thicker line.
