i have a ton of these to cut…how can i move all the lines that are parallel with each other together to reduce the cut to and have it not cut the same line twice
Drag a piece and move the lines over the other line. You have to zoom in a lot for fine tuning. Before cutting, use the optimize window. The option for removing double cuts has to be turned on. Also you have to open this window for the optimization to happen.
But do not expect too much. With my pieces the time was reduced by only about 1-3%.
