Cut out of of bounds
I got problem just set up my laser and lightburn software and anything I am trying to cut I am getting this message"Cut may be out of bounds-continue anyway? yes or no "
If i click yes laser going to the side and make a noise trying to force out of rail. What I should change in settings,please help
It sounds like you may be selecting the incorrect 'Start From’ position. Here are a couple of resources to help you get familiar with the way this setting works:
If your laser doesn’t have limit switches (I do not think your model does), you’ll need to manually home your laser to the bottom left corner before turning it on in order to use ‘Absolute Coordinates’ mode.
If you’re still having trouble, verify that your machine’s dimensions are set correctly in your ‘Device Settings’, making sure to pay attention to units.
You can find these settings by going to ‘Edit’ > ‘Device Settings’ or by clicking the wrench icon in your top tool bar.
