Is there a way to do a cut sequence where you choose each individual part you would like to cut in an order? Thanks for the help!
You may be able to set the Priority in Shape Properties for each shape such that you have complete control of sequence order but I have not tried this on a large number of objects in any meaningful way.
Where can you find Shape Properties?
If the window is not currently available then Windows->Shape Properties.
More information here:
Shape Properties - LightBurn Software Documentation
Thanks! I will check it out.
