Hello, I’m trying to use the Cut Shapes function to divide a graphic for use in a Print and Cut situation for my laser passthrough. I noticed that Cut Shapes is completely grayed out when I select an open shape, so I have selected the border of my shape and run the close path function. When I then go to use the Cut Shapes function, my shape is deleted. I’ve attached a sample lbrn file, and a gif showing the problem.
The Cut Shapes tool creates two results - one that is everything inside the cutter, and one that is everything outside it. So the cutting shape must be closed so the software can work out what’s within it.
