Hey guys; I’ve got a shape here that I cannot get to close, when I use cut shapes ( I am set to fill). I get the required result when using a simple shape - but not the “I/16 Plywood fuselage doubler”. There is something wrong with this shape. I got it from a dxf file for the plane I am working with.
you will note in the attached file the doubler over my laser work space and the cutter - I cannot get this combination to cut and close the shape.
Below my laser work space and to the Right - I made a simple rectangle and used the same cutter - it cuts it and closes it as expected.
Thx - I found that and fixed it - but I still cannot get the “cut shapes” to give me a closed shape with the locating tab I have drawn on the cutter.
In the lower right sketch - executing a “cut shapes”, does give me the result when using the same cutter. So there must still be something else wrong with the “fancy” shape.
