Hi all, nice to find you all. I recently fitted a Chinese 40W laser diode to my MPCNC running on Ramps 1.4/Marlin board. The laser has 12v PWM and hence run it from D9 socket on the board using M106/M107 commands. However, I notice there is a delay in firing up the laser when first firing. This is less of a problem during the middle of the cut when presumably the diode is charged enough to support fluctuations without requiring 200ms to start cutting again.
After reading a bit it looks like the solution is to active cat through. However, for marlin boards this toggle button does not exist. If I change my machine to say GRBL then the button exists. See image attached. Solutions anyone, pls?
