The result of the cutting is an incomplited oval, with contiunuos change on result based on the different try. Any suggestions.
Regards
It’s hard to say when there is so little information, but to rule out that your dxf is corrupt, you could start by posting it here.
as you can see from the pic nress, one cut is the same as the other. I specify that the plywood cutting was done with LaserGRBL.
I converted the .dwg file to .dxf wuth an other program and the problem is gone. Thank you for your support.
Besdt regards.
Carmelo
