I have the. Two TeesTTS-10w laser engraver. The description says it will cut board but I can’t seem to figure out the settings to be able to cut through. Any suggestions would be appreciated!
Here’s the material test list from Two Trees that should be a good reference for starters.
Hope this helps.
Thanks but my laser is not on this chart.
The material test chart given is just a reference, it shows the settings for cutting and engraving plywood.
But it doesen’t say what type/grade of plywood, (hardwood, softwood, composite) your speed and power will be different for each one.
The same for acrylic, is it cast or extruded.
Testing with scrap material is the best way to find out.
LightBurn has a Material Library to save the settings for your particular material you tested.
Check out this doc for more info.
