Hello I have a problem with cutting circles and it is oval despite the fact that i set the steps but i am wondering if i may have forgotten something. I have a working surface of 900x900 and I burned at the beginning (y) and moved by 800mm and again burned and measured and I did exactly the same for the (x) guide.
Thank you very much.
Try asking your main question again - You said that you burned circles 800 mm apart, but you didn’t say what the actual problem was.
I calibrated the steps so that the distance is exactly 800mm because it is more accurate at a long distance than on a small problem, I am sending a picture of an oval circle in a circle
It’s possible that your machine is not quite square - measure the diagonals as well.
