…but 2 layers seem to be doing something different. I tried importing the svg and dxf files, and I tested one of the layers from both file formats, and it does the same thing.
Looking at the first image in the upper left section, the cream-colored “V” shapes have different weight or thickness to what is showing in the upper-right. I can also see that these sections are not lined up.
I suspect the saw tooth parts you are seeing is just artifacting in the pic, but I tossed that version I was cutting since it was not cutting out right.
After downgrading to 9.20, I was able to run the entire job larger and in cardboard, which I spray painted.
No jagged edges to be seen.
But the fact that things were not lining up was why I was posting in the first place. Some of the layers were so off that they were outside the borders when trying to cut with 9.21.
Nice, yet we don’t have further information about what happened and why you got the result you did. Like to get that sorted when using our latest to understand what happened.
