Why doesn’t my average MDF 3mm cut to the end, but it jumps somewhere and doesn’t cut?
It is a CO2 laser 9060 130W, speed parameters 31mm /sec, power 85%
What’s your min power setting? Power may be getting too low on deceleration to the point where the laser is cutting out. You may be able to mitigate by increasing min power.
THANKS [berainlb]. The problem was minimal power as you said. Now it cuts perfectly.
Regards
