I am working on a fitted insert made out of EVA foam that goes into a watertight case. I have multiple parts that are cut from the foam that require multiple passes. In my tests Lightburn will burn the first part X (whatever the number of passes I have set) number of times before moving on to the next part. Is there a way to tell Lightburn to do 1 pass on each part at a time and then start the next pass on the first part. In other words I would like to complete one cut of all parts before it starts to do another pass. Thanks all.
Instead of setting to 2 passes, create a duplicate sublayer with 1 pass each. That should do what you’re suggesting.
On the fiber, the screen to start it has a count option… something like that would be handy for a co2 and fiber I think…
Your normal processing of layers, then the ability to repeat the group of layers… I use it quite often with the fiber… could use it with the co2 and probably the dpssl also.
Sorry about being a bit tipsy with the artwork… ![]()
