Hello,
I would like cut everything behind yellow line, maybe lightburn has fast solution to do it?
Because i cutting all lines by hand one by one.
I honestly have no idea what this means. Please use more words and maybe an example of the desired result, so we can “see” what you are after. We can go from there.
I would try.
Everything outside 26 number square should be not engraved. Is there any fast way would be to make it? Now I use “Edit nodes” and delete lines with “T” one by one.
If your map was an image you could use a mask. If your map is vectors you could try converting to bitmap first, then applying the mask.
Ah yes, I’d forgotten about that function! Still, I’ve got the excuse that I’ve only been using LightBurn for two weeks
