Hi: I am cutting fabric from a template. The cut line on the template is dotted/dashes. I need to make it solid to cut on my laser. Can’t figure out how to do it. Help?
Can you upload one of your patterns?
I will give it a try
H is one of the patterns that the cut line is dotted.
If you select the inner shapes and offset them out, you can use the result of them to get your desired sizes. The offset is about 0.3345" for each shape. I added radius corners in the corners that were chamfered, but s/b OK. Lite blue lines are reference only. Red lines are the new cut lines
Thanks, Ralph…I will give that a try tomorrow. Thanks so much for your help.
Ralph, that works. Thanks so much for spending so much time on this.
Tom
