Hello guys
When I start my CO2 sitting machine , normally the cutting head move to the 0-point then comeback to the last cutting point,
But now the cutting head not move to the 0-point,
Thank you very much jack for your reaction
I will try to explain with my poor English
When I start then machine the only light continue burning is nr 15 during the reset ,
After the reset finished ofcourse the cutting head not moved , the light nr 14 is branding but not continue.
Well when I move the the bar (the bar that holding the cutting head) when I move it to the front , the bat stops suddenly, and then I press on the reset button on the controller then the cutting head is moving to the 0- correctly , then I can cut also correctly,
I don’t know why not start immediately like before
Thank you for your answer Jack
I would inspect it to ensure there are no ‘shorts’ in the drag chains and all the wiring is really connected. You can pull ‘gently’ on the wires on the controller and ensure there are tight. I’ve see a couple that were held only by the glue and lasted a year or so before they failed…
Do a general ‘mechanical’ overview to ensure it’s an electrical issue and not something caused by the mechanics…
There has to be something… does it just look normal?
The ‘bar’ that the head is mounted on is usually referred to as the ‘gantry’…
