I searched for a answer, but found none. Is there a way to cut on either side of a line, not ON the line. I am wanting to try some Marquetry, and am having trouble, and wasting a lot of material up sizing the inlays by %.
Ray
When the layer is set to âLineâ, LightBurn provides settings allowing you to define a âkerfâ offset to your cuts. Double-click the âLayerâ to expose the âCus Settings Editorâ window.
Thanks for the reply. I am at work right now, and cannot try this. Are negative numbers allowed in this setting?
Negative numbers offset the cut âInwardsâ where positive numbers offset âOutwardsâ.
Thanks so much
Ray
Just to chime in hereâŚthis Kerf control is an AWESOME feature for marquetry and inlay work.
itâs reliable and repeatable, and makes it possible to achieve the near impossible.
iâve done a few complex veneer jobs using just one shape plus the kerf control.
Thanks Barrie, I will measure my bean width tonight and begin playing with the settings
Ray
