Cutting Issue using Node editing
I made some shapes with the pencil and used node editing. When I cut them out it is leaving tab or spots where it is not cutting. Any suggestions on why this is happening??1 2 3 4
A picture of the design file and the settings used would be helpful. You may have the new Tabs feature enabled.
A quick check for a closed shape is to change to fill - if it doesn’t fill, its not closed.
Post the lbrn file.
