Cutting leather, corners not completed
I am using a Ray5 10 watt diode laser to cut out my leather, but I am finding that in rounded corners I frequently need to use a hand knife afterwards, as there are one or two spots where the laser did not cut completely (or cleanly). Thoughts, suggestions on how to get those corners cut completely?
a thought….on the MIN power setting in LB is it lower than Max ?
if yes, bump it up so when the travel slow down around the corners it does not reduce the power too much…..
but watch for burning !
That’s only for DSP controllers; GRBL does it automagically.
GRBL reduces the power as it slows down at corners, but rounded corners shouldn’t require much slowing down.
The Troubleshooting guide has a few suggestions:
However, those spots could be variations in the leather, in which case just crank on Moah Powah to ensure complete cutting.
When cutting anything, I use Constant power. Only when engraving do I enable Variable power.
