I have a diode laser machine, and I recently purchased a CO2 laser machine.
The issue is that the CO2 machine was cutting very slowly, taking practically the same amount of time as the diode laser. In this case, I am cutting thin paper at high speeds.
For example:
With the diode laser, I would cut a file at a speed of 2,200 mm/min, and it would take 1 minute and 20 seconds. I then used the same file on the CO2 laser at a speed of 100 mm/s, and it took the same amount of time to cut.
In the CO2 machine settings, there were different parameters for the X and Y axes (as shown in the image). Following Gemini’s suggestion, I increased and matched the parameters for the X axis, and now the machine is operating at a much higher speed.
Now I can set the speed to 80 mm/s, and it cuts the file in half the time or even less.
My question is: Could this cause any problems or damage to the machine?
That is an excellent way to completely screw up your system, because Gemini (and its relatives) know nothing and just predict which word is most likely to follow the pile it already produced.
The stepper motor on the Y axis must move a much heavier gantry than the stepper motor on the X axis, so it will have a lower acceleration and Corner Speed. It may also have a lower maximum speed, although sellers tend to over-specify those values.
There’s another group of overriding settings / percentages for the Idle, Cut, and Engraving speeds & accelerations that, most likely, are limiting whatever values you enter for each axis.
At this point, you should restore the original as-shipped controller settings using Machine Settings → Load from Backup, because those settings will be closer to correct than whatever Gemini suggested.
The overall time to complete a project depends more on its layout, cut settings, and optimizations than controller settings, so show us what you’re trying to accomplish and the hive mind will surely have some suggestions.
For example, an intricate paper layout will proceed very slowly, because the laser cannot accelerate to high speeds along very short vectors. You may be able to optimize the vectors to improve the speed, but it probably won’t be a factor of two faster.
What puzzles me most is how a diode laser with a cutting speed of 2200 mm/min—which converts to 36 mm/s—takes the same amount of time as a CO2 laser with a cutting speed of 100 mm/s.
That’s why I tweaked the settings.
I don’t understand why the CO2 laser is cutting so slowly; it doesn’t match the commanded speed.
Do you have any idea what might be causing this?
It’s always nice to hear you got a new machine. Believe me it’s newer to me than it is to you You need to tell us more about what is the machine you have. Gemini has lots of machines. You can also add that new machine to your personal profile. I think it’s the bottom item on the License Management tab. If you left click on the user name, you can read the profile.
I have a glass tube OMTech with a Ruida controller. Here are my settings, just to give you an idea of how wide a range we might use. I have collapsed the Cut Parameters, as far as I know, you can’t pick which. I haven’t pushed very hard to get the Y axes faster. I have a lightweight head, which removed a lot of mass. The only other thing I have on the head is air.
This is mine doing a test run at 889mm/s (35in/s) trying out a new coating. It’s way too long at 4 minutes. As soon as you’ve seen enough, you can bail.
Give us the type, dc or rf, how fast you’re going, lens length, and power settings. It’s more difficult for us to dived by 60 and compare your comparison..
I went to mm/s on my cnc machine and it was an easy move to mm/s on the co2. I keep all of my machines and software using mm. I can look at it and have a good idea how fast it’s running.
Hang in there, you’ve got a great start and understand more than most.
Different wavelengths will have different results on the same material. You will discover materials where it is better to use the diode, and some where the CO2 is a better choice. Be glad you have both.
